Date/Time: Tue, 29 Sep 2026 08:03:33 +0000
Unknown Exception Caught in Spreadsheet Study Function.
View Count: 936
| [2016-05-23 09:06:43] |
| wat - Posts: 67 |
Hello, i have little trouble. I try find here answer for my problem, but not find. http://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php And here in Support Board i try to. If you i export with Spreadsheet study data to standart sheet no problem. If you i export with Spreadsheet study data to excel, i have only ticker. Thank you for time |
| [2016-05-23 09:13:00] |
This is not within the scope of our support. We provide 0% support for using Excel. We will not get involved with this. The documentation for the "Use Excel" input makes this very clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-23 09:13:17
| [2016-05-23 09:40:39] |
| wat - Posts: 67 |
OK.
