Date/Time: Tue, 29 Sep 2026 08:03:29 +0000
Linear regression end chanel bug?
View Count: 983
| [2016-05-23 08:39:35] |
| djcurcio - Posts: 236 |
The channels vanish when I set the Start Date Time to yes (midnight) and have a number greater than 1 in the Number of Bars. The documentation states "Number of Bars: The number of bars from the last bar in the chart to calculate and draw the Linear Regression line and channel lines across. This does not apply if Use Start Date/Time instead of Number of Bars is set to Yes." I am trying to have multiple channels, all starting at midnight, but with each channel as different length in bars to achieve a channel duration for the full day and several day parts. How can I achieve this? Thanks |
| [2016-05-23 09:11:01] |
In the Start Date and Time Input make sure you specify the date as well. This type of study Input was recently changed and the Date control needs to be separate. We will fix that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
