Date/Time: Tue, 17 Nov 2026 00:14:31 +0000
Edit / Download Daily Data for All Symbols
View Count: 1630
[2016-05-23 07:46:38]
Lesmond - Posts: 22
This command seems to be permanently greyed out (v1406):
http://i.imgur.com/7VGBPGq.png
How to get it working? This is the fastest way to update all daily bar data files (DLY files).
This functionality was removed in v702 for some reason and I have been waiting for it to come back ever since. I know about:
Edit / Download Daily Data for Associated Watch List Symbols
but it is a workaround that requires two extra steps:
1) you need to manually enter each new DLY symbol into the watch list
2) you need to first open a chartbook with this watch list to be able to run data files update.
Date Time Of Last Edit: 2016-05-23 08:24:38
[2016-05-23 09:42:28]
OK we will add support for this command in the next release.
[2016-05-28 07:20:14]
Lesmond - Posts: 22
I can see the command is not greyed out any more in v1419 but it doesn't work, no DLY data gets downloaded.
[2016-05-28 08:02:13]
Yes, after we made changes to this we later realized that it does not do what you want.
This actually was developed for internal use and does not download data for all files. It only downloads Historical Daily data for symbols being tracked in real time by Sierra Chart.
You really need to use the Associated Watch List for a chart:
Changing the Symbol of a Chart: Using the Associated Watch List
To be clear, we are not willing to to add what you are looking for.
Date Time Of Last Edit: 2016-05-28 08:03:20
[2016-05-28 08:55:43]
Lesmond - Posts: 22
No problem. I can live with associated watch lists.
This question keeps coming back from time to time from new users migrating from other platforms who trade stocks. They like to have hundreds of symbols updated with a single click. In case there is later more demand for this functionality, server load could be managed by daily data caps.
[2016-05-28 23:53:11]
This is already supported through the Associated Watch List and the related command for it on the Edit menu.
We see no reason for any further functionality. The downloading is done as needed and also on command.
