Date/Time: Tue, 29 Sep 2026 08:03:57 +0000
DRAWING_RECTANGLE_EXT_HIGHLIGHT Until Hit
View Count: 1763
[2016-05-21 20:54:11]
User56866 - Posts: 28
Hi
When using the GUI for drawing tools I see Sierra can detect when the extending rectangle (DRAWING_RECTANGLE_EXT_HIGHLIGHT in ACSIL) is hit by price, is it possible to access this functionality in ACSIL?
Best regards,
Ben
[2016-05-21 21:50:38]
What do you mean by this?
What is your question here?
[2016-05-21 22:55:51]
Sorry for the vagueness.
I want to draw a marker on the chart when the current price hits the Extending rectangle.
[2016-05-21 22:57:37]
It is possible to get user drawn drawings using ACSIL:
Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing()
So you can then use that data in the way that you require.
