Date/Time: Tue, 29 Sep 2026 08:04:02 +0000
Pre-download Historical data for a watchlist without opening individual chart
View Count: 1240
| [2016-05-21 19:11:06] |
| SK - Posts: 33 |
How do I download historical data for a list of symbols prior to actually opening the individual chart for those symbols. Day trade bunch of hot stocks, so I constantly change symbols in the associated watchlist but do not open the chart until its needed, so its taking precious seconds of my execution time by the time it opens up the historical and intraday data. Would like to know if this can be done in background by sierra without actually opening the chart. |
| [2016-05-21 22:53:42] |
Yes this is supported. Historical or Intraday charts?
| [2016-05-21 22:55:51] |
For Intraday charts, refer to: Global Settings Menu: Intraday File Update List (Global Settings menu) This section here explains how to do this for Historical Daily charts: Study/Chart Alerts And Scanning: Understanding Scanning Historical Daily Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-21 22:56:10
| [2016-05-22 02:21:27] |
| SK - Posts: 33 |
when does the download begin for intraday and historical charts after the symbols are added to Intraday file update list. It seems data downloaded does not start immediately
| [2016-05-22 02:31:19] |
We have updated the documentation to explain this: Global Settings Menu: Intraday File Update List (Global Settings menu) Also the Intraday File Update List does not apply to Historical Daily charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-22 03:41:39] |
| SK - Posts: 33 |
Documentation doesn't clarify when dies the download begin. Is it milliseconds after updating list ? seconds after? Or later?
| [2016-05-22 04:34:34] |
It is immediate. It does not need to be documented because it is apparent through simple usage and it is implied. You can simply test it and verify it for yourself. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-22 04:36:40
