Date/Time: Tue, 29 Sep 2026 08:03:34 +0000
Bar Numbering
View Count: 986
[2016-05-21 17:49:16]
mkata - Posts: 103
There is a slight inaccuracy present on the current CLN6 contract when using the Bar Numbering Study with a 1_range or 1_tick chart with the start time set at 18:00:00.
Please see attached from 5-19-2016.
imageCLN6 0.01 Range .png / V - Attached On 2016-05-21 17:45:45 UTC - Size: 41.57 KB - 351 views
imageCLN6 1 Trades .png / V - Attached On 2016-05-21 17:45:55 UTC - Size: 30.17 KB - 450 views
[2016-05-21 22:23:28]
mkata - Posts: 103
I think I solved the problem by changing the code from SCDateTime to SCDateTimeMS.
[2016-05-22 00:15:34]
Interesting, OK we understand the nature of the problem.
That solution appears to be correct. We will look at this carefully and implement the appropriate solution.
