Date/Time: Tue, 29 Sep 2026 08:03:58 +0000
[Programming Help] - Request for simple code/indicator
View Count: 1428
[2016-05-21 07:37:06]
EuropeanTrader - Posts: 290
Hello everyone!
Can someone please create some sort of alert (colored bar or a dot signal beyond a bar) when a simple criteria is met:
"A bar opens at 20% extreme and closes on the other 20% extreme of its price range".
For example:
Low of bar is 100, high is at 200. Open is at 120 and close is at 180. You see that Open/Close of that particular bar were on the extreme ends, at their 20% extremes.
Attached is also a visual example (not all examples are circled, just a few so you get an impression).
The idea comes from Linda Raschke's book Street Smarts where she made some statistics that show very high odds of breaching that bar's high/low the next day. It's a good quantitative model within good trend trades could be made).
Thank you!!
Date Time Of Last Edit: 2016-05-21 07:38:00
image8020s.png / V - Attached On 2016-05-21 07:37:15 UTC - Size: 29.09 KB - 541 views
[2016-05-21 12:57:40]
jackw - Posts: 57
Copy the study collection file below to your data directory, and then apply it to your chart. It will color any bars that meet the extreme criteria.
attachmentExtremes-.StdyCollct - Attached On 2016-05-21 12:57:01 UTC - Size: 9.4 KB - 574 views
[2016-05-23 04:22:38]
This looks awesome!
Thanks a lot "jackw"
