Date/Time: Tue, 29 Sep 2026 08:03:58 +0000
DTC and rejected orders
View Count: 1185
[2016-05-20 22:12:14]
T29_Dev1 - Posts: 22
I think there is some issue with order rejecting.
When I send a parent order + OCO and SC reject them, I get the order update message with rejected state only for OCO orders and not for the parent order (this order looks missing - no logs, no acknowledgment, nothing).
Also I can't see any information about rejected orders in the SC log.
In my tests I get rejected order when I send OCO with order type ORDER_TYPE_UNSET for one of OCO orders.
[2016-05-21 00:04:28]
This will be solved in the next release. These are lower-level errors which will not be logged in the Trade Activity Log and the orders will not be added to the order list either as rejected orders because they have some significant problem with the basic fields.
[2016-05-22 18:26:14]
onnb - Posts: 666
I assume you mean in the next release there will be a rejected message for the parent order?
What version will that be in?
[2016-05-22 19:34:37]
Yes. The version will be 1416.
