Date/Time: Tue, 29 Sep 2026 08:04:03 +0000
Opening Range Midline
View Count: 2775
| [2016-05-20 21:50:16] |
| greg9 - Posts: 9 |
Sierra Chart I have been able to adapt the "High/Low for Time Period - Extended" study to be an opening range on my chart. I set the bottom line to fill up and the top to fill down and now have a good looking opening range. http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s246 The one missing piece to this is i'm trying to get the Opening range midline, basically the value equal distance from top to bottom. Is there an indicator or something to run a custom calculation of OR high and OR low and plot a midline? Been trying to figure that out with no success.... Thanks |
| [2016-05-21 00:55:55] |
You need to use Study Subgraphs Average for this: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-21 16:24:56] |
| kinghat - Posts: 120 |
the initial balance study will plot a range and a midline for you as well in one study. |
| [2016-05-21 21:49:59] |
| greg9 - Posts: 9 |
Thank you this is very helpful. There always seems to be a way to do things in Sierra, just takes me a minute to figure them out. Thanks for the help. |
