Date/Time: Tue, 29 Sep 2026 08:03:57 +0000
[Programming Help] - ACSIL: skip a holiday
View Count: 2465
[2016-05-20 20:08:46]
SSS - Posts: 16
Hi.
I'm running the following code to build an array of valid trading days (with the ultimate purpose of drawing lines on them). I've managed to exclude Saturdays and Sundays, but how do I check if a given date is a holiday? For instance no volume occured, or the high could not be obtained.
SCDateTime firstDate = YMD(2016, 5, 9);
  SCDateTime Days[9]; //declare an array of datetimes
  Days[0] = firstDate; //assign first array element the value of firstDate
  for (int n=1; n<9; n++)
   SCDateTime newDay = Days[n-1] + 1*DAYS; //add one day to the first date
   if (newDay.GetDayOfWeek() == SATURDAY) newDay = newDay + 1*DAYS; //if it's a Saturday, add another day
    if (newDay.GetDayOfWeek() == SUNDAY) newDay = newDay + 1*DAYS; //if it becomes a Sunday after addition, add one more day
    if (???date is a holiday???) newDay = newDay + 1*DAYS; //how do I check if it's a holiday. How to obtain volume at the date of newDay?
    Days[n] = newDay;
I appreciate if you can point me in the right direction. Thanks in advance.
[2016-05-20 20:18:45]
Cavalry3162 - Posts: 523
maybe use an online service like http://www.bank-holidays.com/index.htm ?
there might be some free services out there too.
[2016-05-20 20:22:43]
SSS - Posts: 16
Thanks for the tip, Andreas. The problem is getting this to work for different symbols.
I thought I might check sc.High[newDate]. If it returns zero (or an error), then I'll add a day.
The problem is sc.High expects a bar index as its argument. I can't seem to find a way to determine the bar index of a given date.
[2016-05-20 20:26:40]
yeah, different countries bring in some complexity..
no data might work, but isnt 100% as there are some "half trading day" holidays in the US or on some holidays GLOBEX session is open but cash markets are closed.
maybe you build a database per exchange and check against it?
[2016-05-21 00:50:24]
Not having sufficient Intraday data for a particular day or no intraday data for a particular Weekday would be a good way to check for this. You could use this function:
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scCalculateTimeSpanAcrossChartBars
