Date/Time: Tue, 29 Sep 2026 08:04:05 +0000
DTC Protocol Server Failed
View Count: 1706
| [2016-05-20 02:26:12] |
| User713273 - Posts: 409 |
Hi, what is the relevant issue if any, Ive attached the below log for reference. Thx DTC Protocol Server failed to start listening on port 11099. | 2016-05-19 19:22:38 * Listening socket (1076), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-05-19 19:23:38 * Listening socket (1076), port 0 | Closed. | 2016-05-19 19:23:38 DTC Protocol Server failed to start listening on port 11099. | 2016-05-19 19:23:38 * Listening socket (1076), port 0 | Failed to bind socket to 0.0.0.0:11099. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2016-05-19 19:24:38 * Listening socket (1076), port 0 | Closed. | 2016-05-19 19:24:38 DTC Protocol Server failed to start listening on port 11099. | 2016-05-19 19:24:38 * |
| [2016-05-20 02:34:48] |
Refer to the documentation here about this: http://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#ResolvingDTCProtocolServerPortNumberConflicts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
