Date/Time: Tue, 29 Sep 2026 08:03:33 +0000
GetMaxChartId api?
View Count: 1030
| [2016-05-19 18:35:49] |
| onnb - Posts: 666 |
hi - Does it make sense for you to add an api int GetMaxChartId() that returns the max chart id currently in use in the chartbook? Also, is there a constant for the maximum charts possible in a chartbook? |
| [2016-05-19 18:38:19] |
If you need it, we can add this. Do you want us to add this? We would call it sc.GetHighestChartNumberUsedInChartBook There is no constant for the maximum number of charts. There is no limit placed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-19 18:38:47
| [2016-05-19 18:46:17] |
| onnb - Posts: 666 |
This would be helpful and we would use it right away. We iterate over all charts in the chartbook. Currently users inputs the maximum. Users often forget to update this value as chartbook grows and then go figure ;) Date Time Of Last Edit: 2016-05-19 18:46:34
| [2016-05-22 22:37:40] |
This will be out in the next release.
