Date/Time: Tue, 29 Sep 2026 08:04:11 +0000
[Programming Help] - color background based on alert condition
View Count: 1679
[2016-05-18 19:49:30]
Chris H - Posts: 5
I would like to write a formula using the color background base on Alert condition (unless there is a better study) When the CCI is crossing (or has just crossed) the +100 line in a downward direction and the Moving linear regression length 4 is crossing (or has just crossed) the Moving linear regression length 9 in a downward direction (20 degrees min. if possible): I would like both MLR to be going in the same direction (downward) with 20 degrees when the alert trigger; an arrow would work if the background is making difficult to figure.
Then just the oppose with the CCI crossing the -100 line and the move linear regressions crossed and moving upward. You are welcome to call me or do a remote link if that would help (713-992-5220)
ID9.SG1=CCI line
ID9.SG3= +100 line
ID9.SG4= -100 line
ID7.SG1=moving linear regression 9
ID6.SG1=moving linear regression 4
=AND(CROSSFROMABOVE(ID9.SG1,ID9.SG3),CROSSFROMBELOW(ID6.SG1,ID7.SG1)) When the CCI line crosses the +100 downward and LR4 crossed LR9 going down
=AND(CROSSFROMBELOW(ID9.SG1,ID9.SG3),CROSSFROMABOVE(ID6.SG1,ID7.SG1)) When the CCI line crosses the -100 upward and LR4 crosses the LR9 going up
do I need an "study angle" for direction what number of bars to calculate?
[2016-05-18 21:05:13]
Sawtooth - Posts: 4355
Try these:
=OR(AND(CROSSFROMABOVE(ID9.SG1,ID9.SG3),ID6.SG1>ID7.SG1),AND(ID9.SG1<ID9.SG3,CROSSFROMBELOW(ID6.SG1,ID7.SG1)))
=OR(AND(CROSSFROMBELOW(ID9.SG1,ID9.SG4),ID6.SG1<ID7.SG1),AND(ID9.SG1>ID9.SG4,CROSSFROMABOVE(ID6.SG1,ID7.SG1)))
These will go TRUE when the CCI crosses the OB/OS lines and the MLRs have already crossed,
OR when the CCI has already crossed the OB/OS lines and the MLRs cross.
You don't need to use the Study Angle study if you don't care about the degree angle of the line.
Date Time Of Last Edit: 2016-05-18 23:17:45
[2016-05-19 14:13:17]
Chris H - Posts: 5
I am getting every cross of the moving linear regression 4 & 9, not just a cross after the +100 or -100
[2016-05-19 18:28:49]
Those formulas will give an alert at every MLR directional cross if the CCI is inside the OB/OS lines.
What specifically do you mean when you say "or has just crossed"?
[2016-05-19 20:50:23]
Chris H - Posts: 5
The only cross of the MLR directional cross I would like to see is the first time the length 4 crosses the length 9 after the CCI has crosses the +100 downward. Currently I am getting the crosses when the CCI crosses the +100 going upward above +100 AND downward plus every cross between the +100 and the -100 lines of the CCI. I only want the first cross after the CCI crosses the OB/OS line, not all of them;' if this is possible . The CCI has went through the +100 and up to +180 then turned and headed back through the +100 toward the zero line, the first time that the length 4 crossed the length 9 after the CCI has penetrated past the +100 is the cross I am trying to get the alert on and visa-a-versa.
Thank you for your help Chris Hageman 713 992 5220 cell
[2016-05-19 21:53:39]
This is more complex than Simple Alerts can do. It could be done with the Spreadsheet System/Alert study.
There would need to be a formula to set a persistent TRUE when the CCI crossed, then release it when the MLRs crossed.
Then replicate it for the other direction. It would take at least 4 formula columns.
Date Time Of Last Edit: 2016-05-19 21:54:00
[2016-05-20 01:53:33]
Chris H - Posts: 5
Thank you for your help, I will try to do a much simpler alert
[2016-05-20 03:24:16]
These formulas will eliminate some of the alerts because they require the CCI to be on the OB/OS side of zero:
=OR(AND(CROSSFROMABOVE(ID9.SG1,ID9.SG3),ID6.SG1>ID7.SG1),AND(ID9.SG1<ID9.SG3,ID9.SG1>0,CROSSFROMBELOW(ID6.SG1,ID7.SG1)))
=OR(AND(CROSSFROMBELOW(ID9.SG1,ID9.SG4),ID6.SG1<ID7.SG1),AND(ID9.SG1>ID9.SG4,ID9.SG1<0,CROSSFROMABOVE(ID6.SG1,ID7.SG1)))
See bolded above. You could experiment with using a value other than zero to eliminate more spurious alerts.
[2016-05-20 11:56:28]
Chris H - Posts: 5
I will try this thank you for the extra effort may you have a blessed day Chris Hageman
