Date/Time: Tue, 29 Sep 2026 08:49:43 +0000
Merge Numbers Bars Option
View Count: 1151
| [2016-05-18 16:33:25] |
| User49270 - Posts: 89 |
Hi, I was wondering if there are any plans in the future to add a feature to be able to merge Numbers Bars on the chart. I know you can get similar volume information with the Volume Profile tool or changing the chart period but I think it might be useful. Thanks
| [2016-05-18 17:14:30] |
No. Definitely not. Merging is accomplished simply by changing the timeframe of the chart bars. If you want merge functionality you need to use TPO Profile Charts: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html Or manually draw Volume Profiles on the chart and adjust them: http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#DrawVolumeProfile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
