Date/Time: Tue, 17 Nov 2026 00:14:33 +0000
[User Discussion] - $tick data for Crude Oil (Nymex)
View Count: 1095
| [2016-05-17 23:07:54] |
| User636069 - Posts: 26 |
Hello Folks, Two questions: 1- Does anyone know what $tick data should be used for crude oil (Nymex) trading? For instance, for S&P500, $tick-NYSE is used. Thanks in advance! 2- Is anyone using the Relative Volume indicator? if so, it would be appreciated if you could share how you use it efficiently? Thanks! |
| [2016-05-29 17:10:22] |
Hi Why don't you answer my question or publish it publicly?! |
| [2016-05-29 17:28:29] |
1. This is not available and would not make any sense because this is just a single symbol.
