Date/Time: Tue, 29 Sep 2026 08:49:22 +0000
CQG + AMP = REPLAY CHART NOT WORKING ?
View Count: 1092
| [2016-05-16 16:38:16] |
| User367949 - Posts: 25 |
Hi There, I have SC with AMP and CQG data its been working great. But for some reason when I go to backtest my algo now the replay chart doesnt work when its pressed? Its all on and auto trading enabled and worked before, any ideas? thanks! |
| [2016-05-16 17:44:22] |
Refer to the instructions here about this: Replaying Charts: Basic Chart Replay Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-16 21:55:39] |
It was workig fine and now it isnt ? Any Ideas on what it could be? those instructions helped beforew not now |
| [2016-05-17 01:09:11] |
No because we do not know exactly what you are doing and what you are seeing. The instructions also give you additional steps on what to do in this case. We have no idea if those were followed and what the reaction is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-17 10:19:42] |
FIXED THANKS
