Date/Time: Tue, 29 Sep 2026 08:49:24 +0000
Use keyboard arrow keys to move to next or previous chart
View Count: 1262
| [2016-05-16 15:02:06] |
| User686554 - Posts: 3 |
I previously had SierraChart installed, then my computer crashed and I had to reinstall and start over. Previously, I could move through the chartbook symbols by pressing the arrow keys on my keyboard. Now I'm only able to do it using the F4 and F9 keys. I would rather do it with the arrow keys. Can you tell me how to do this?
| [2016-05-16 18:34:35] |
You need to set up Keyboard Shortcuts for this: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
