Date/Time: Fri, 13 Nov 2026 20:19:56 +0000
How do I change chart to standard time?
View Count: 3570
| [2013-07-10 19:17:33] |
| User86222 - Posts: 10 |
In Ninja Trader, I am able to have under the chart PST (Pacific Standard Time) since I live in California. In Sierra Charts, it looks like it's on military time. The main issue is that I would like to see standard PST time with for example it showing 10 am in the morning on the bottom of the chart, and then later 12:30 pm not military time. Also, but not as important, I would like it to show days of the week. For example, after 12 midnight on Mon, you should see the word Tue at the bottom of the chart. Is there a way to do this or can you add it as a feature to a later release or patch of the product? |
| [2013-07-10 19:42:19] |
Refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_TimeZone.html You can enable the display of the day of week through Chart >> Chart Settings >> Advanced Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-02-05 13:07:41] |
| User284663 - Posts: 44 |
Is this still possible? I too would like 12 hour am/pm time, could not find this option anywhere.
| [2019-02-05 17:34:40] |
No that is not supported.
