Date/Time: Tue, 29 Sep 2026 08:49:25 +0000
saving indicator values
View Count: 1228
| [2016-05-15 20:22:24] |
| amirN - Posts: 169 |
I have coded some indicator based on the the DOM data. Is it possible to save the indicator values (what is being displayed) before closing SC so that when I reopen SC I can get back the indicator as was drawn in realtime? As DOM data is not available for historical data yet, whenever I reopen SC it would try to recalculate the indicator and I loose my displayed values. |
| [2016-05-15 20:55:15] |
No, this is not supported.
| [2016-05-16 07:37:18] |
Then how can I capture the indicator values in excel so that I can use an external program to visualize the data.
| [2016-05-16 08:49:34] |
You can use the Spreadsheet study for this: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
