Date/Time: Tue, 29 Sep 2026 08:49:40 +0000
SC1412 Connected/Connection Lost Alerts not working
View Count: 1006
| [2016-05-13 22:42:16] |
| TechTrader - Posts: 116 |
Alerts set in General Settings >> General 2 >> 'Server Connected Alert' and 'Server Connection Lost Alert' not sounding in SC1412
| [2016-05-13 22:48:06] |
We do not see a problem with this. Refer to: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-13 23:14:04] |
Alert Sounds were Muted - Unchecking fixed the issue. For the record, the sounds were not muted previously. Also an installation of SC1412/SC1413 using 'SC Forex Data (FXCM) [data]' alerts worked normally. |
| [2016-05-14 04:02:05] |
We know why this is happening now. It is due to array bounds violation problem that we need to fix. We are doing this now. It is somewhat serious of an issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
