Date/Time: Tue, 29 Sep 2026 08:49:41 +0000
intraday data
View Count: 830
| [2016-05-13 19:22:10] |
| madra - Posts: 109 |
Hello, I have installed IB and Sierra on my laptop as I need to travel. All of the setup on my desktop for sierra does not transfer to the laptop. Is there a way to transfer all the sierra chartbooks on my desktop to the laptop? thank you Charlie |
| [2016-05-13 19:35:32] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-14 03:10:16] |
I need more help to transfer data from my desktop to my laptop. I have copied data folder to desk top of of the source computer. I do not know how to copy this folder to the laptop. I'll have to leave it if I do not hear fropm you very soon. |
| [2016-05-16 09:22:15] |
How to copy data from one computer to another is not within the scope of our support. A simple way of doing it though would be to put it on a USB drive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
