Date/Time: Tue, 29 Sep 2026 08:49:40 +0000
Time alert limitation
View Count: 916
| [2016-05-12 16:30:52] |
| calitrader - Posts: 28 |
That is the character limit for the Edit/Enable Time Alert field? Could the text be wrapped in the comment box to allow multiple lines or the new line character be added? In example "Step1\nStep2\nStep3" to create a new line after each step in the comment box. Thank you, Chris |
| [2016-05-13 02:48:30] |
This is not supported but we will allow it. If it causes odd display behavior though we will not help with it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-13 02:48:49
