Date/Time: Tue, 29 Sep 2026 08:49:20 +0000
Is it Possible to Use Any Indicator To Code an ACSIL Trading Study?
View Count: 837
| [2016-05-11 21:17:13] |
| User417726 - Posts: 9 |
I'm ask this because on this page: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#top it doesn't show all the available indicators. Can I code any indicator or just the ones provided on the link I posted? Thanks |
| [2016-05-12 04:30:36] |
Yes you can. Refer to: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
