Date/Time: Tue, 29 Sep 2026 08:49:21 +0000
Draw volume profile every X volume traded.
View Count: 1006
| [2016-05-11 18:57:59] |
| User15952 - Posts: 137 |
Is it possible to draw a profile every X number of volume traded. I am looking at a 2t renko and would like to draw a profile every 50k contracts traded. Thanks |
| [2016-05-11 19:19:39] |
This is not currently supported but will be in about a month or two.
| [2016-05-11 19:21:25] |
That will be AWESOME, thanks!
