Date/Time: Tue, 29 Sep 2026 08:49:21 +0000
Alert sounds not playing after upgrade to Windows 10
View Count: 1073
| [2016-05-11 18:52:34] |
| djcurcio - Posts: 236 |
I upgrade from W7 to W10 I am running TransactMA My sounds play ok when tested from Global Setting > General Settings > Alerts . General 3 >Alert Settings > Test Sound The sounds also show in the Sound Mixer when tested. The Alert Manager windows shows the alerts - but no sounds play Help please Thanks |
| [2016-05-11 19:22:09] |
Refer to the section here: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
