Date/Time: Tue, 29 Sep 2026 08:49:23 +0000
"Clock - RealTime" study in DOM not visible
View Count: 1665
| [2016-05-11 16:53:55] |
| User305145 - Posts: 38 |
Hi, Wish to see the time/clock in the DOM. Attached pic shows it behind the VAP - I cannot seem to bring it to the front or change it's position... (despite adjusting "initial horizontal/vertial position..." inputs) How can I solve this? /Martin |
| [2016-05-11 17:02:26] |
There is very little room to move it. You cannot move it right of the Buy column. You need to widen the Trade DOM window to make more room. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-11 17:02:48
