Date/Time: Tue, 29 Sep 2026 08:49:26 +0000
assistance with correct order entry configuration
View Count: 906
[2016-05-10 15:34:23]
User604413 - Posts: 5
Hello, I'm having some difficulty figuring out the correct order entry method for my desired configuration.
Here I will provide the scenario.
Total order quantity = 5 contracts.
After 3 ticks gain I'd like to sell 1 contract.
After 4 ticks gain I'd like to sell 1 contract.
After 5 ticks gain I'd like to move the stop order to -2 (negative) tick gains.
After 6 ticks gain I'd like to sell 1 contract.
The final 2 contracts I'd like to use a trailing stop where the stop follows market price and follows by 3 ticks.
This should work the same for both long and short position. Knowing what types of orders to use for each type of scenario would be a big help.
[2016-05-10 19:33:03]
The attached Trade Window Configuration should do what you want or at least get you started.
To use it, refer to:
Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You
attachmentTradeWindowConfiguration_20160510.twconfig - Attached On 2016-05-10 19:32:22 UTC - Size: 6.18 KB - 514 views
