Date/Time: Tue, 29 Sep 2026 08:49:21 +0000
Missing Data
View Count: 926
| [2016-05-10 15:05:15] |
| tellerbe - Posts: 109 |
My tool bar is across the top of my chart. Just beneath it is an empty space that once held such data as: open,high,low close, volume, etc. It was tied to the crosshair. I would like to get it back but I don't know what it is called. Help! T.Ellerbee |
| [2016-05-10 18:59:03] |
You now need to use the Compact Tool Values Window for this: Chart Drawing Tools: Compact Tool Values Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
