Date/Time: Tue, 29 Sep 2026 08:49:24 +0000
Custom DLL study causing CPU exception
View Count: 1688
| [2016-05-10 08:40:55] |
| User240686 - Posts: 86 |
This has never happened before. I upgraded to latest version and this happened so i rolled back, rebooted but still get this message Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:35:42 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:35:42 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:35:51 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:35:51 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:35:53 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:35:53 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:35:56 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:35:56 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:36:01 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:36:01 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:36:17 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:36:17 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:36:24 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:36:24 * The above has been sent to support. | 2016-05-10 10:36:54 * HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-10 10:36:54 HTTP connection to www.sierrachart.com:80 (10) | Connected. | 2016-05-10 10:36:54 Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2016-05-10 10:36:54 HTTP connection to www.sierrachart.com:80 (10) | Closed. No error. | 2016-05-10 10:36:59 HTTP connection to www.sierrachart.com:80 (10) | Shutdown and closed. | 2016-05-10 10:36:59 Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:37:24 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:37:24 * Warning: The Custom DLL study "futuresfx-sc.scsf_powerlines" has just caused a CPU exception. | 2016-05-10 10:38:12 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2016-05-10 10:38:12 * |
| [2016-05-10 09:44:08] |
Update to the latest "Prerelease" following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-10 10:08:37] |
No I had to go back to 1374 to get it to work properly
| [2016-05-10 10:23:59] |
OK not really sure about this because this is a study that we did not develop and we are not exactly certain what the reason for the problem is.
