Date/Time: Tue, 29 Sep 2026 08:49:45 +0000
Subgraph study text above/below bar
View Count: 1032
| [2016-05-09 17:34:01] |
| apollofl - Posts: 95 |
http://www.sierrachart.com/image.php?Image=1462815056470.png anyone got this study to align the delta below the bar correctly. |
| [2016-05-09 21:25:18] |
This will be solved in the next release now that we understand the problem.
| [2016-05-10 04:09:11] |
Thank you Support. You guys are SUPER.
