Date/Time: Tue, 29 Sep 2026 08:49:44 +0000
cumulative delta study not starting at 0?
View Count: 920
| [2016-05-09 16:07:37] |
| kinghat - Posts: 120 |
i have CD study set to start a new session. today i noticed that when the server opened it started above 0. never seen this before. is this normal or is there a bug in the CD?
| [2016-05-09 17:01:02] |
Yes this is normal and expected. Refer to the Inputs description for Cumulative Delta Bars for further information.
| [2016-05-09 17:16:18] |
thanks for the response and i checked out that input definition again. its just odd because ive only seen it happen a couple times. normally it always starts at 0.
