Date/Time: Tue, 29 Sep 2026 08:49:41 +0000
trading abroad
View Count: 903
| [2016-05-09 10:29:12] |
| User750374 - Posts: 14 |
Hi there, I am using sierra charts in UK and it works great, but I am moving back to China later, will I be able to use Sierra there? Like will the speed of receiving real live data be lagged? Many thanks! |
| [2016-05-10 05:34:12] |
You really have to test and verify this yourself. But we do not expect you would have any problem.
