Date/Time: Tue, 29 Sep 2026 08:49:44 +0000
Diagonal Dominant Side coloring.
View Count: 1093
[2016-05-09 04:16:06]
Rino - Posts: 124
I have the numbers bar set at 300% to color a number on the Diagonal Dominant Side.
In the instructions it says " Also, the Ask volume at the lowest price level and the Bid volume at the highest price level do not have a value to compare against and are not colored."
However it is coloring it as shown.
I have researched and can not see how to stop it.
Thanks as always,
image1aaa.jpg / V - Attached On 2016-05-09 04:13:41 UTC - Size: 191.56 KB - 522 views
[2016-05-09 04:48:16]
We will test this.
[2016-05-10 05:31:08]
Refer to the documentation for this input here:
https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#EnableDiagonalZeroBidAskCompares
