Date/Time: Tue, 29 Sep 2026 08:49:45 +0000
Kansas City Wheat ticker (KW)
View Count: 1416
| [2016-05-08 23:23:17] |
| fdan - Posts: 7 |
Hello, Using Sierra dataservice + IB Trading service I cant find symbols of KW. Datafeed works fine for any other symbol. If I use only Sierra realtime data with no trading service connected, then I can use KW symbols. Best regards |
| [2016-05-09 02:22:59] |
Can you provide us a link to the details for this futures contract on the Interactive Brokers website and then we can set it up.
| [2016-05-09 03:28:11] |
| fdan - Posts: 7 |
https://pennies.interactivebrokers.com/cstools/contract_info/v3.9/index.php?action=CONTRACT_DETAILS&clt=1&mid=001&site=IB&conid=160548349&detlev=2&sess=1462764387 Thanks |
| [2016-05-10 06:14:27] |
This has now been added. Update the Symbol Settings as explained here: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
