Date/Time: Tue, 29 Sep 2026 08:49:43 +0000
Sierra Chart Header
View Count: 1102
| [2016-05-08 22:36:15] |
| User21113 - Posts: 62 |
Sierra Chart Application Header The Sierra Chart application header reads Sierra Chart 1392 <Chartbook name.cht> SC Data - All Services 2016-05-08 12:00:00 Mon DF:1000 ST:50 Within the header, the date, time and DF, ST information continually update. Is is possible through the application to deselect all the continually updating items (date, time, DF and ST) so the header does not continually update? |
| [2016-05-09 00:37:46] |
No. You cannot change this.
