Date/Time: Tue, 29 Sep 2026 08:49:20 +0000
Number of Forward Columns
View Count: 1514
| [2016-05-08 09:23:03] |
| User730732 - Posts: 12 |
Hi SC, currently the number of forward columns in the chart settings cannot be reduced below the default value of 150. It would be very nice if that was possible. Best Regards, Thank you in advance! |
| [2016-05-09 21:14:44] |
This will be solved in the next release.
