Date/Time: Tue, 29 Sep 2026 08:49:24 +0000
Study Overlay-Color Intraday Bars based on Previous Day close
View Count: 1142
| [2016-05-07 15:54:07] |
| vectorTrader - Posts: 86 |
I have a chart(called it chart#1) of the vix where I use color bar based on Above/Below based on the previous close. I would like to overlay this chart(chart#2) with the color condition on a separate chart using study/price overlay. When I do,the color condition does not show on the chart#2. IS there a way to do this? thanks http://www.sierrachart.com/image.php?Image=1462636409756.png |
| [2016-05-09 10:19:24] |
Make sure "Use Colors from Source Study" Input with the Study/Price Overlay study is set to Yes. We tested this and it does work properly when overlaying the Color Bar Based On Above/Below study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-09 10:20:07
