Date/Time: Mon, 21 Sep 2026 06:43:44 +0000
sierrachart.h is not downloaded correctly with new installation pre-release 1407;
View Count: 1159
| [2016-05-07 15:24:24] |
| @sstfrederik - Posts: 413 |
Upgraded to pre-release 1407. sierrachat.h is not downloaded. contents of file looks like this. <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>404 Not Found</title> </head><body> <h1>Not Found</h1> <p>The requested URL /downloads/1407/sierrachart.h was not found on this server.</p> </body></html> Also the other files in ACS_SOurce are the same. studies.cpp etc. Some issue with the new installer? Date Time Of Last Edit: 2016-05-07 16:43:13
| [2016-05-07 18:16:08] |
We know about this. We are working on the new installer and this will be solved in a few hours. For the time being the prerelease cannot be installed but it is not any different than the current version anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
