Date/Time: Tue, 29 Sep 2026 08:49:43 +0000
Saving formula in Spreadsheet trading
View Count: 1072
| [2016-05-06 10:11:58] |
| User210074 - Posts: 63 |
Hello I have a serious problem with the spreadsheet trading. It does not keep my formulas despite the backup. Indeed when I restarts (after saving,) the spreadsheet trading are always empty. can you help me ? |
| [2016-05-06 15:16:48] |
What is the version number of Sierra Chart that this occurs with? This may not be related but also refer to the documentation for Formula Source Sheet Number: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-09 21:11:27
| [2016-05-09 14:03:23] |
Version 1406
| [2016-05-09 21:11:44] |
Most likely this is related to the Formula Source Sheet Number input which is documented here: Spreadsheet Study Inputs: Formula Source Sheet Number Read through that information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
