Date/Time: Tue, 29 Sep 2026 09:38:38 +0000
Can I put together/combine two indicators (RSI and MACD) e.g. and merge one
View Count: 2233
| [2016-05-05 09:29:16] |
| User134797 - Posts: 56 |
Hi All, Can I put together/combine two indicators (RSI and MACD) e.g. I what both indicator merge one, is this possible? Best, Iwan |
| [2016-05-05 09:59:46] |
Yes. The general method is to use the Based On setting which is documented here: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
