Date/Time: Tue, 29 Sep 2026 09:37:40 +0000
Midpoint question
View Count: 1516
| [2016-05-04 20:10:07] |
| User747654 - Posts: 39 |
I currently use the Initial Balance study to view the midpoint. What I don't like is that as the midpoint changes the plot changes for the entire day rather than drawing the new value while still showing where the old midpoint was. I have used two other charting platforms in the past that both drew the midpoint the way I am describing. For reference I have attached an image of one of the charts. The white line is the midpoint and I would like to be able to do this with my Sierra Chart charts. Would you be able to help? Thanks |
| [2016-05-04 23:09:42] |
Did you want the developing midpoint of the entire day? It sounds like you want to use the Daily OHLC study instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
