Date/Time: Tue, 29 Sep 2026 09:37:39 +0000
DOJY ALERT
View Count: 1469
| [2016-05-04 14:13:24] |
| User145792 - Posts: 22 |
hI, I TRIED TO COMBINE AN "AND" ALERT INWHICH ONE OF THE OBJECTS IS DOJY. I WROTE o=c or o[-1}=c[-1] but it doent work . what should be the press that creates dojy? Thanks |
| [2016-05-04 15:12:56] |
O=C is a valid formula. Use it with the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-05 05:50:03] |
thanks, but still by only using O=C I am getting no results how can i combine the results of the study "CandleStick Patterns Finder" for dojy as the color alert |
| [2016-05-05 06:12:44] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-05 06:20:23] |
SORRY, I DO NOT UNDERSTAND YOUR ADVICE. IF I WANT TO HAVE A FORMULA INSIDE "COLOR BASED" INWHICH ONE OF THE "ANDS" IS A DOJY (WHAN THE OPEN=CLOSE) HOW CAN I DEPLOY IT?
| [2016-05-05 17:38:37] |
We want to see an image of the chart you want to apply this formula to. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
