Date/Time: Tue, 29 Sep 2026 09:38:37 +0000
depth of market in trial version
View Count: 1090
[2016-05-04 00:51:55]
User519438 - Posts: 2
Hello Support,
What needs to be done in order to receive market depth with TDAmeritrade (TOS) during the SC market trial? Thanks.
[2016-05-04 02:50:19]
This is just not supported.
[2016-05-04 05:11:48]
Bedhog - Posts: 187
Hello Support. I was helping this guest with the charts and was mistaken about the functionality. Is this a TDA limitation or is there no market depth in the trial version?
Ha - I found it: Is Historical and Real-time Data Included?
The TD Ameritrade service does not provide real-time futures data. This is something that you must be aware of if you are using TD Ameritrade.
Date Time Of Last Edit: 2016-05-04 05:19:49
[2016-05-04 05:33:51]
The answer to the question is not very simple.
But basically there is no Futures data or stock market depth data that you can access when using Sierra Chart with TD Ameritrade unless you use the Sierra Chart Exchange Data Feed:
