Date/Time: Tue, 29 Sep 2026 08:49:43 +0000
Control board chart drawing commands malfunction
View Count: 1052
[2016-05-03 16:38:59]
ktfroy - Posts: 85
The commands 'Copy And Adjust Chart Drawing' and 'Adjust Chart Drawing' are malfunctioning when accessed on the Control Bar. Specifically, when clicked between the 2 anchor points on a line they copy and move the drawing rather than adjust it.
When these commands are accessed via Right Click menu they work properly.
Date Time Of Last Edit: 2016-05-03 16:48:17
[2016-05-04 01:21:55]
We will solve this problem but when using these commands and left clicking on the drawing in the middle, the beginning will always be adjusted.
[2016-05-06 12:06:04]
ktfroy - Posts: 85
Is it possible to link to specific Chartbooks via a custom Control Bar Command ?
This is assuming that the chartbooks are currently open.
Date Time Of Last Edit: 2016-05-06 13:00:10
[2016-05-06 15:10:10]
No.
[2016-05-09 15:06:34]
ktfroy - Posts: 85
This issue has not been resolved as yet in version 1406
[2016-05-09 17:27:52]
This was definitely resolved. But not certain it is in version 1406.
