Date/Time: Tue, 29 Sep 2026 09:37:37 +0000
My ES futures charts do not move unless I keep disconnecting and connecting the chart,
View Count: 890
| [2016-05-03 02:24:29] |
| User239482 - Posts: 2 |
I am a new user of sierra chart on a 15 days free trial version it shows all are green means the connection is good |
| [2016-05-03 05:02:12] |
Refer to: Is Historical and Real-time Data Included? You really should be aware, that there is no chance to be getting real-time futures data this easily for free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
