Date/Time: Tue, 29 Sep 2026 09:38:37 +0000
Above Below Open Price
View Count: 1142
| [2016-05-02 14:35:35] |
| User623839 - Posts: 108 |
Need your help. What I would like is to plot an above below study like the zero line on the MACD EXCEPT: I would like to use the "Open" price as my zero line and have the bars color red below green above open price? see attached |
| [2016-05-02 18:46:59] |
Have a look at the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 You should be able to do what you want with that study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-02 18:47:28
| [2016-05-03 01:34:13] |
thanks
