Date/Time: Tue, 29 Sep 2026 09:38:14 +0000
Chartbook background
View Count: 1063
| [2016-05-02 12:50:41] |
| User447007 - Posts: 44 |
How could I change the color of the chartbook background. I am unable to find that option, I could change the chart's and anything else's background but of the chartbook ( main window background )... Another problem: I setup es mini session time from: 08:30-15:15 but the last five minute is missing on the 10 minutes chart, If I set up till 15:20 then also missing the last five minutes. The one minutes chart start with 15:30, but the first bar should be 15:31? So what settings should I set? Sorry for that basic questions, but I am new at sierra and haven't found that settings ony your page. |
| [2016-05-02 17:55:57] |
Not sure how to change the color of the main Sierra Chart window background. This is going to be something controlled by the Windows operating system. There may be a color setting for it in the Windows Control Panel. All of the time settings mentioned are not valid because they do not follow this format: Hours: Minutes: Seconds We recommend carefully reviewing the related documentation here: Chart Session Times The one minutes chart start with 15:30, but the first bar should be 15:31?
The first bar should be at 15:30:00 So what settings should I set?
We do not know. That is for you to decide.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-02 17:57:06
| [2016-05-02 20:29:00] |
| Sawtooth - Posts: 4355 |
Sierra Chart time stamps the start of the bar, not the close of the bar as some charting packages do. Because of this, it's best to set the End Time to 15:14:59 If your Session Times are 08:30:00 to 15:14:59 on a 1 min chart, the first bar will be timestamped 08:30:00 and the last bar will be timestamped 15:14:00, but it will contain data until 15:14:59. If your Session Times are 08:30:00 to 15:14:59 on a 10 min chart, the first bar will be timestamped 08:30:00 and the last bar will be timestamped 15:10:00, but it will contain data until 15:14:59. |
| [2016-05-02 20:42:30] |
Could I change that timestamp someway? As I use another softwares it is a little bit confusing. I would prefer the first bar 08:40:00 in a 10 min chart. |
| [2016-05-02 20:55:46] |
No, this is definitely not changeable.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-02 20:55:55
