Date/Time: Sat, 08 Aug 2026 03:34:12 +0000
Bad NQ data
View Count: 864
| [2016-04-29 12:56:50] |
| User66360 - Posts: 81 |
My NQ has gaps all over the place, bad data. I have deleted data and downloaded almost everyday for a month. Its still the same. The daily chart is ok, but anything intra day is terrible. How do I resolve this? thank you
| [2016-04-29 14:15:21] |
You need to update to the current version of Sierra Chart. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate A notice about this is being given when you start Sierra Chart. After that is done re-download the data in the chart with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-04-29 18:07:57] |
that worked, thank you
