Date/Time: Sat, 08 Aug 2026 03:35:58 +0000
Issue with deselected chartbooks and "multiple selection"
View Count: 807
| [2016-04-29 03:14:02] |
| i960 - Posts: 360 |
If one selects a bunch of chartbooks with multiple selection enabled and they deselect a chartbook, that chartbook will still be included on open.
| [2016-04-29 04:22:20] |
We will check on this.
| [2016-04-29 15:31:18] |
This has been corrected. Follow the instructions here to update Sierra Chart to the latest prerelease: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate The version number has not changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-29 15:31:31
