Date/Time: Tue, 29 Sep 2026 10:32:44 +0000
[Programming Help] - Color Bar Based on Alert
View Count: 1435
[2016-04-26 11:11:26]
User937866 - Posts: 12
I have used the Posts on Support Board to learn how to color bars based on alert but I am trying to do something a little more complex. I would like to have bars colored green/red based on MACD being above zero line AND above the Mov Avg of MACD. Otherwise I would like them to not be colored. How can I accomplish this? I would also like to add another alert indicator in which a Green Arrow is Below a Candle if RSI is Above 70 and a Red Arrow is Above a Candle if RSI is Below 30. How may I accomplish this?
[2016-04-26 12:45:52]
jackw - Posts: 57
Copy the 2 study collections below to your SC data directory.
Open a new chart and add the AAA study collection (from the Analysis menu). It will add a MACD and the color bar studies to the chart.
Open another new chart and add the BBB study collection. It will add an RSI and the color bar studies to the chart.
Once you see how I did it, you can replicate the logic on your charts.
Date Time Of Last Edit: 2016-04-26 14:07:08
attachmentAAA.StdyCollct - Attached On 2016-04-26 12:43:36 UTC - Size: 28 KB - 450 views
attachmentBBB.StdyCollct - Attached On 2016-04-26 12:43:49 UTC - Size: 28 KB - 439 views
[2016-04-26 14:05:26]
Thank you for the replay. It does not seem that the files attached. Could you please resend? Thank you.
[2016-04-26 14:08:18]
jackw - Posts: 57
You should be able to see them now in the post above.
[2016-04-26 14:09:12]
Thank you
